Date/Time: Thu, 06 Feb 2025 07:16:17 +0000
percent change previous days RTH last (close) to current intraday last price
View Count: 895
[2020-04-17 13:33:21] |
User731787 - Posts: 5 |
Is there an existing study that shows the percent price change for the current intraday last price to the PREVIOUS days (RTH) (close) last price. If not, using the spreadsheet formula study (C-C[-1])/C[-1]*100, any suggestions on how I hold the C[-1] constant at previous days RTH (close) last?
[2020-04-17 14:48:51] |
Sawtooth - Posts: 4169 |
This is what I use on a 5 min chart:=IF(AND(MROUND(BARTIME[-1],1/86400)<TIMEVALUE("16:14:00"),MROUND(BARTIME,1/86400)>=TIMEVALUE("16:15:00")),C[-1],ID1.SG1[-1]) where ID1 is the Spreadsheet Formula study. This assumes chart bars are timebased. It returns a persistent price at the close of the 16:10 bar. Date Time Of Last Edit: 2020-04-17 16:22:25
[2020-04-17 18:40:41] |
Also take a look at this study: Percent Change Since Previous Close Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
