Date/Time: Sat, 18 May 2024 08:16:30 +0000
Flatten Positions and Cancel Orders at Set Time when SC is not working&lost internet conn
View Count: 992
[2020-04-17 11:47:24] |
User156295 - Posts: 104 |
Flatten Positions and Cancel Orders at Set Time - settings done from Global P/L and Chart Trade Window - is it working when the platform is already closed or internet connection is lost while using TT/Denali through AMP and enabled Server Side options in General Trade Settings?
[2020-04-19 01:29:57] |
Flatten Positions and Cancel Orders at Set Time - settings done from Global P/L and Chart Trade Window Sierra Chart must be running and connected to the trading server for this functionality to work.If you have enabled and are using Server Side OCO and Bracket Orders, then these orders are managed on the server and do not require connectivity from Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-20 19:20:10] |
So how to control it using TT/Denali through AMP? Is there any other way to control open positions and orders while having SC or internet temporary problems but during important moments? |
[2020-04-20 19:28:38] |
@TRADE_YOUR_PLAN - Posts: 126 |
Yes, subscribe to their web trading panel. I've tested it. It works very well.
[2020-04-20 19:37:59] |
Thank you for the response. How to subscribe to web trading panel, was on Main Control Panel and do not see where to subscribe.
[2020-04-20 19:40:49] |
ok, found smth like here https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#WebBasedTradingPanel |
