Date/Time: Mon, 25 Nov 2024 04:58:45 +0000
Seasonal Spreads
View Count: 1305
[2014-01-15 10:26:45] |
User80231 - Posts: 1 |
Could you give me a recipe how to work with appropriate charts if I want to trade seasonal spreads with Sierra? thanks
[2014-01-15 17:46:20] |
We recommend using the Difference (Bar) study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
