Date/Time: Thu, 06 Feb 2025 05:09:37 +0000
$TICK Question
View Count: 550
[2020-04-16 23:21:48] |
User745552 - Posts: 3 |
I am looking for the $TICK chart for Sierra. It is the one that monitors all 2800 stocks in the NYSE and gives the difference between up and down. I see all kinds of Tick charts in the ones available, which is the one that represents the standard $TICK? Thanks so much.
[2020-04-17 05:15:54] |
This has already been answered: $TICK Comparison Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
