Date/Time: Thu, 06 Feb 2025 05:15:28 +0000
Wrong numbers in Trading Window (DPL)
View Count: 610
[2020-04-16 23:15:30] |
User702497 - Posts: 1 |
Dear Sirs, Since a few days ago I am seeing wrong DPL numbers in the trading Window. P/L is correct but not the accumulated Daily PL, which is a bit confusing as it may show an incorrect win or loss (mainly big loss). My current version is 2040 64 bit. Please let me know if you need further description of the problem. Thanks |
[2020-04-17 09:50:24] |
In regards to this, refer to this page: Help With Daily Profit/Loss Value Also that documentation is up-to-date as of the latest version, so you need to update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-17 09:50:43
