Date/Time: Sat, 19 Sep 2026 00:09:12 +0000
Change chart number?
View Count: 2912
[2020-04-16 20:22:38]
rainbow47 - Posts: 68
Is it possible to change the #number of a chart?
[2020-04-17 00:17:44]
No it is not possible.
[2020-04-17 01:01:17]
Sawtooth - Posts: 4354
You can duplicate the chart and it will have a new number, then delete the original.
If another chart has the chart number you want to use, dupe it first, and delete its original.
Caution: this method will cause dislocations of overlaid studies and copied chart drawings.
Date Time Of Last Edit: 2020-04-17 01:04:11
[2020-04-17 08:09:13]
Ok, I try to find a way to jump to a chart with a hotkey. So far I tried to do this in one chartbook but it looks like I can only set hotkeys for "previous/next chart".
I thought I might use one chart per chartbook then (multipile chartsbooks open) and jump to the chartbook by hotkey. I can set hotkeys for chartbooks but for some reason it does not jump to the chartbook when I press the button.
What the best way to do it?
[2020-04-20 09:28:33]
Any idea hot to get the "Chartbook Keyboard shortcuts" working?
[2020-04-20 19:00:00]
Keyboard shortcuts for Chartbooks require Control Bar buttons to be configured first:
Control Bar: Control Bar Chartbook Buttons
