Date/Time: Thu, 06 Feb 2025 05:18:08 +0000
Customize Control Bar
View Count: 551
[2020-04-16 16:19:19]
User897697 - Posts: 11
Hello, after the update to 30839M the customize tool bar does not show symbals but text anymore.
It is almost impossible to find the tools anymore. This is not good
I read how to change it, but therefore i have to edit each control bar element on its own and set "picture" instead of "text".
Is there at least a way to do this at once for all control bar elements?
best regards
[2020-04-16 16:27:48]
John - SC Support - Posts: 37769
There is not a way to change them all back at once. You just have to follow the instructions here, particularly Step 10:
Control Bar: Control Bar Button Properties
[2020-04-16 18:38:47]
Refer to the notes for version 2065 here. It explains a fast method to update the buttons:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2065
It should just take a couple of minutes.
