Date/Time: Thu, 06 Feb 2025 05:05:36 +0000
Sierra datafeed - Eurex without depth ?
View Count: 614
[2020-04-16 12:08:03] |
Acro - Posts: 441 |
Hi, Is there likely to be any option going forward to get the Eurex Retail feed that is charged at 2 Euros per month through Sierra or Denali ? Thanks |
[2020-04-16 12:37:51] |
We are not aware of this. And also if you are referring to the non-tick by tick feed we would never offer that.
[2020-04-16 12:37:52] |
[2020-04-16 12:40:37] |
Acro - Posts: 441 |
No, it is tick by tick data. Described by Eurex here: https://www.mds.deutsche-boerse.com/mds-en/data-services/real-time-market-data/derivatives-markets/Eurex-Retail-Europe-1339980 |
[2020-04-16 18:29:11] |
We will check on this.
