Date/Time: Thu, 06 Feb 2025 05:00:07 +0000
TWS data feed through the Sierra chart and place orders through SC API?
View Count: 626
[2020-04-16 03:33:18] |
User333339 - Posts: 3 |
hello. I am currently getting a data feed through interactive broker’s TWS. Is this possible to connect the TWS data feed through the Sierra chart and place orders through SC API? And is it possible to access the SC API by account? |
[2020-04-16 07:06:37] |
Yes. Here are the set up instructions: Interactive Brokers Trading Service: Setup Instructions Not sure what you mean by SC API but Sierra Chart does have this: Advanced Custom Study Interface and Language (ACSIL) Data and Trading Communications (DTC) Protocol Server When submitting an order, you can specify the trade account it is for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-16 07:07:00
