Date/Time: Thu, 06 Feb 2025 04:36:47 +0000
Futures
View Count: 495
[2020-04-16 00:12:36]
User850090 - Posts: 26
Hi. What is ticker for ES futures, NQ futures, RUS futures, DOW futures. And do I have to pay more then just basic $38 to get this data? Thanks Lou
[2020-04-16 14:48:48]
John - SC Support - Posts: 37769
The exact symbol you need to use is dependent on what Trading/Data Service you have selected. In order to find the symbol, you need to use the File >> Find Symbol window. You can then scroll through the options there, or use the Search option on that page to find the particular symbol you are looking for. Refer to the information here:
File Menu: Find Symbol (File)
