Date/Time: Thu, 06 Feb 2025 04:51:37 +0000
Connection error: "Trade account not assigned"
View Count: 502
[2020-04-15 20:28:31]
Ollie - Posts: 1
I have Sierra Direct with Denali data. The broker is Infinity. I thought I set it up correctly and entered my account number. However, I am on a delay no mater what I try.
Also, should I be logging in through my previous Infinity icon ( I previously had Sierra enabled through Infinity) or should I be logging in through the new Sierra Icon?
I have tried to connect on both with no luck.
[2020-04-16 11:57:23]
You need to follow the Transact setup instructions here:
https://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions
If you have any difficulty connecting, then refer to:
https://www.sierrachart.com/index.php?page=doc/TransAct.php#AccountLogonError
Yes.
