Date/Time: Thu, 06 Feb 2025 04:59:18 +0000
Daily P/L
View Count: 557
[2020-04-15 18:42:36] |
User176071 - Posts: 7 |
The Daily P/L is not being reset to 0 for each new session. The amount displays from the prior session. This is happening in sim and live
[2020-04-15 18:56:43] |
Update Sierra Chart to the current version. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
