Date/Time: Thu, 06 Feb 2025 05:02:19 +0000
DATA real times
View Count: 491
[2020-04-15 17:56:29]
guy2306 - Posts: 1
WAY I DONT GET REAL TIME ?
[2020-04-15 18:29:27]
The reason you are not getting real-time data from the CME group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
We recommend using the above solution in any case to avoid this problem in the future.
