Date/Time: Thu, 06 Feb 2025 05:07:13 +0000
LMAX: decommissioned instruments
View Count: 489
[2020-04-15 16:58:57] |
AlexPereira - Posts: 197 |
Hi, Just a notice for SierraChart symbols with LMAX. LMAX decommissioned the instruments: * WS30 * SPX500 * TECH100 * GER30 Now only the mini version of those instruments exist. I don't know if it matters, on their email of this notice, WS30m has the same security ID as WS30 previously ( and the same for other instruments ). Is this updated and somehow I still have old symbol settings ? Thanks ! |
[2020-04-15 19:30:15] |
We would not remove these symbols. They need to remain so that historical data is accessible. Perhaps they might be removed after about a year.
