Date/Time: Thu, 06 Feb 2025 05:18:35 +0000
Upgrade to Current Version
View Count: 593
[2020-04-15 15:25:44] |
John Mc - Posts: 32 |
I am trying to upgrade to the current version, 2074. I have tried many alternatives (restarted PC, cleared cache on browser, run the update process a number of times) but it still will not update. The log file shows the below. Installer version: 9 | 2020-04-15 10:06:27 What do I need to do? Thanx - john |
[2020-04-15 18:19:18] |
The current version is now 2083. So it looks as though the installer is running, but is there an error message once the installation completes? Here are the detailed instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-15 18:19:35
