Date/Time: Thu, 06 Feb 2025 03:43:50 +0000
[Programming Help] - ACSIL - Chart Drawing Tools and Custom Studies interaction
View Count: 553
[2020-04-15 08:48:21]
User365411 - Posts: 192
Since it is not possible to create a custom Chart Drawing Tool I wanted to know if it is possible to create an interaction between standard Tools and a Custom Study to obtain something like this, (also explained in the attached image):
- manually add a vertical line "Line1" on a candle that is important for me
- add a custom study that draw another line "Line2" that is 25 bar on the right of the Line1
- then, if i move the Line1 in a new position, Line2 will move accordingly referencing to Line1 new position and maintaining same 25 bar distance
If it's possible I would be grateful if you could refer me to some code examples ( I don't find nothing in the ACS_Source folder) or some functions that allow this specific interaction.
TY
imagetest_tools.png / V - Attached On 2020-04-15 08:45:28 UTC - Size: 51.84 KB - 217 views
