Date/Time: Thu, 06 Feb 2025 03:56:40 +0000
Trading Multiple Accounts Which Use Differing Data Services
View Count: 569
[2020-04-15 05:20:03] |
User371562 - Posts: 14 |
Is there a way to integrate/automate trading across multiple accounts which use differing Data/Trade Service Settings?
[2020-04-15 11:53:14] |
Only by installing separate installations of Sierra Chart: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
