Date/Time: Thu, 06 Feb 2025 04:14:19 +0000
TPO charts
View Count: 511
[2020-04-15 00:44:51] |
Jim colitz - Posts: 1 |
Was trying to open TPO charts in separate window next to my es bar charts. when I click apply it puts in same window and hides the chart. What should I do? Thanks much |
[2020-04-15 03:31:19] |
It is not possible to have TPO Profiles with a standard bar chart. It will replace the standard chart bars.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-15 04:43:05
