Date/Time: Thu, 06 Feb 2025 04:50:49 +0000
Using AMP Sierra Chart with other brokers
View Count: 680
[2020-04-15 00:10:29] |
User841513 - Posts: 15 |
Hi. If I have an account with AMP Futures and get the SC package 3 from them, can I use that same SC to connect to and get data feed from my other brokers also supported by SC such as FXCM and IB? If so, can I also place orders with all of them once connected an trade from the SC app? (FXCM and Interactive Brokers) Thanks! |
[2020-04-15 11:16:38] |
No you will need a direct account in this case: Direct Sierra Chart Account Also, to trade different accounts, refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-15 15:58:03] |
Thank you very much for your reply. No you will need a direct account in this case:
Direct Sierra Chart Account I have read the link provided but please forgive me to ask since was not clear for me. Does having a direct account with Sierra means that besides the offer from the broker to use Sierra, I have to pay to Sierra also for it to work with other data services/brokers? Or is just a thing of having the login account (the one I am using now) and a different folder Sierra installation for it to work? Thanks! Date Time Of Last Edit: 2020-04-15 15:58:46
[2020-04-15 18:21:21] |
Yes you do have to pay for Sierra Chart to us. You just pay once for it.
[2020-04-15 21:55:27] |
Ok Thanks! Everything is clear now.
