Date/Time: Thu, 06 Feb 2025 03:47:26 +0000
Please confirm SC ORS supports multiple simultaneously active clearing accounts?
View Count: 620
[2020-04-14 23:55:21]
ErikT - Posts: 121
Seems like this should work but the documentation doesn't say it specifically so need to check...
I currently use SC ORS with Advantage Futures. I want to open a 2nd clearing account with a different FCM, and use both accounts with SC. So for any given trade I would select the clearing account from a dropdown showing both my Advantage account and a new account with another FCM on your supported firm list. I would use a single Denali market data feed for trades with both clearing firms.
Please confirm this will work. It would suck to go through all the work of opening another account and then find out it's not supported!
THANKS GUYS!!!
[2020-04-15 11:42:20]
Yes this is definitely fully supported and works like you describe.
Date Time Of Last Edit: 2020-04-15 11:42:26
