Date/Time: Thu, 06 Feb 2025 03:47:14 +0000
period average
View Count: 557
[2020-04-14 18:23:12] |
User236880 - Posts: 15 |
hi, just wondering if there's any study that allows me to see the average value of a certain study (zscore in my case), over a time period (hours, days etc)
[2020-04-14 19:24:09] |
Yes, you could use this particular study: Moving Average - Time Period And then you can base it on any particular study: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
