Date/Time: Thu, 06 Feb 2025 03:53:55 +0000
Sierra Chart + Denali feed + Sierra Order Routing + Which FCM?????
View Count: 1566
[2020-04-14 18:08:22] |
User920967 - Posts: 62 |
Hi Sierra and community, I am trying to achieve the lowest latency & highest quality trading setup for my needs. From my understanding, the combination of using the sierra data service AND the sierra order routing service, should provide the most stable and high speed order execution. My question is which FCM do you guys recommend to use. I understand not showing preferences publicly since sierra works with most FCM/Brokers, but i would really appreciate some guidance here. I am all in on your technology and services and just need the final part of the decision to be made correctly. Your guidance is required. If possible i would really appreciate to setup a call or skype to discuss this briefly. Thanks in advance, and thanks for the amazing software you developed. |
[2020-04-14 19:17:51] |
Whatever clearing firm you use is not going to affect the quality of order routing and market data. Really this is a decision which would be best made by you. The most commonly used ones are AMP and Dorman but Advantage and ADM are supported as well, as well as others. The broker Stage 5 is also supported for this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-14 19:18:14
