Date/Time: Tue, 11 Feb 2025 13:44:30 +0000
Bid and ask volume profiles on chart Dom (not the stand alone Dom)
View Count: 1986
[2020-04-14 15:30:44] |
User968625 - Posts: 260 |
Hello, I can't find a way to add the volume profile for the bid/ask on the chart dom (not the stand-alone dom). Also, is there away to add on the same chart dom the volume profile and the bid/ask volume profile (Agina, the Chart Dom and not the stand-alone dom) Thank you |
[2020-04-15 12:30:43] |
The processes are the same whether you are talking about the Trading (stand-alone) DOM or the Chart DOM. To get the Bid and Ask Volume Profiles in the Chart DOM, select Trade >> Customize Chart/Trade DOM Columns and then select the column you want the profile to be displayed in and select the Show Volume Bars option. Refer to the information here: Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns) We are not sure exactly what you are looking for from the second question, but we think you are asking how to get a regular Volume by Price profile displayed next to the Chart DOM. To do this, just set these two settings in the Volume by Price study: - Right-Align Volume Profiles: Yes - Align to Far Right: Yes Refer to the information here: Volume By Price Study: Right Aligning Volume Profiles with Space on Right Side of Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-08 14:59:21] |
Bedhog - Posts: 179 |
Is there a way to increase the VbP column width in the ChartDOM? Attached is an example from TOS and SC (too narrow to read)
[2020-09-08 15:21:57] |
John - SC Support - Posts: 37869 |
What you are showing in the SC image is not a Volume by Price profile, but is just a histogram of the data in that particular Chart DOM column. To make that bigger, just stretch the size of the column. Refer to the information here: Global Trade Settings Windows: Chart/Trade DOM Column Widths and Headers (Trade >> Customize Chart/Trade DOM Columns) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-09 15:03:45] |
On the stand-alone DOM, what/where is the setting for the blue shaded area below price in this image?
![]() Attachment Deleted. |
[2020-09-09 15:07:17] |
Refer to the following setting and the one after it: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Trade DOM Ask Background For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
