Date/Time: Mon, 28 Sep 2026 10:32:30 +0000
Data package
View Count: 1261
[2020-04-14 15:13:52]
User161549 - Posts: 81
Can you tell me which data package i am using in reference to whether it is CQG or rithmic or possibly another one that im not aware of
I use the CME with Market Depth for nonprofessional Trading accounts
Just trying to get a better understanding of my data plan
[2020-04-14 18:15:03]
You are using the Denali Exchange Data Feed from Sierra Chart for your data. You can find more information on this data feed here:
You are running an older version of Sierra Chart. You need to update:
Is the data you are receiving delayed by 10 minutes?
Date Time Of Last Edit: 2020-04-14 18:16:39
[2020-04-14 19:28:17]
Okay thank you for that information was also trying to put together what the new cost would be monthly with the new CME fees that went into effect on April 1st
and i wasnt aware i am running an older version, no i do not have data delayed everything is in real time
Will this update affect any of my current chartbooks or layouts that i have configured ?
What is it thats different from this update versus what i have now ? as everything seems to be running fine
Date Time Of Last Edit: 2020-04-14 19:29:38
[2020-04-15 11:43:32]
No.
Refer to this page:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php
Also refer to:
Notice: Exception/Stability Issue
