Date/Time: Thu, 06 Feb 2025 03:52:04 +0000
Coffee Prices not showing right
View Count: 768
[2020-04-14 14:15:13] |
User181655 - Posts: 61 |
My Coffee contract rolled over and the prices are again showing in the format that I don't like ie 124.50 is shown as 1.2450. I know how to change this on the vertical grid showing price by multiplying by 100 but the problem is how do I get the dom to show the prices as 124.50 and not 1.2450 |
[2020-04-15 04:58:04] |
If you are referring to the Sierra Chart DOM, then you just need to change it in the same way as you do the chart. On the DOM itself, select Chart >> Chart Settings and change the Historical and Real-Time Price Multipliers. Refer to the information starting here: Chart Settings: Real-Time Price Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) If you are referring to the TransAct DOM, then you would need to ask TransAct how to change that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-15 04:59:05
