Date/Time: Thu, 06 Feb 2025 04:03:27 +0000
Automated File Distribution System - Sierra Chart Version Compiled On
View Count: 864
[2020-04-14 08:28:50] |
Dema - Posts: 42 |
Hi Team, I am new to providing a Custom Study DLL via the Automated File Distribution System. The DLL I created did not get distributed to approved users until they updated their Sierra Chart version. Are you able to shed any light on this, for example do users need to be at least on the version I compiled it on? Thankyou.
[2020-04-14 11:38:58] |
No this is not version dependent. However, there can be other reasons as explained here: Resolving Custom Study File and Access Issues Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-14 11:39:14
[2020-04-14 14:41:26] |
ForgivingComputers.com - Posts: 994 |
Do users need to be at least on the version I compiled it on?
To download the file: No To run it: Yes If the developer builds the DLL on a version that is higher than the version the approved user has, then the study will be downloaded but not loaded. In this case, the user has to update or the developer has to re-build it on an older version. |
[2020-04-15 00:02:50] |
Dema - Posts: 42 |
Hi Sierra Chart Engineering, Thanks for the link - and yes I did go through all the items in it prior to posting, appreciate you including this in your extensive documentation. Could you please confirm Bradh's comment, as the fix is easy (run another older SC installation of SC for compilation purposes only), but I would prefer not to have to bother with multiple SC installations if possible. Thankyou. |
[2020-04-15 11:18:23] |
Yes what is said in post #3 is correct.
