Date/Time: Mon, 25 Nov 2024 16:35:14 +0000
Overlay Charts
View Count: 1524
[2014-01-14 14:14:37]
user511 - Posts: 5
Hi
I need to find a way to overlay 2 different symbols to the same chart.
Example:
http://i.imgur.com/wxv1QXM.png
Here in e-Signal, i overlay 2 charts: AA (NYSE) and PETROBRAS (BMF).
Now, I would really like to do this in SC also ... Overlay some futures with NYSE stocks , for example.
Is it possible guys ?
[2014-01-14 14:39:07]
WarEagle - Posts: 73
Open both symbols in their own charts. Then on the first chart add the Overlay (Bar) study. In the settings window click on "Chart Number to Overlay" and then use the drop down box to select the second chart. Also make sure Chart Region is 1 if you want them to be in the same window pane.
[2014-01-15 17:59:02]
This can be done by using the Overlay (Bar) study:
http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s100
[2014-02-23 17:51:44]
User83762 - Posts: 61
But how is this overlay accomplished without keeping all the overlayed charts open??
[2014-02-23 18:22:37]
As far as I know, its not....I just minimize the extra charts.
[2014-02-23 21:22:00]
Yes. The information given in post #5 is correct.
