Date/Time: Thu, 06 Feb 2025 02:47:25 +0000
[Programming Help] - ACSIL - Check if there is an open stop loss order
View Count: 1102
[2020-04-13 08:11:54]
MattK - Posts: 42
I'm trying to check if there is an open order without a stop loss at any point in time (because I had issues in the past in high volatility environment where an order was placed but the SL was not.
I tried the following:
int Index = -1; //to get the last order placed.
if(sc.GetOrderByIndex (Index, OrderDetails) != SCTRADING_ORDER_ERROR)
if(OrderDetails.OrderStatusCode == SCT_OSC_FILLED)
//Flatten and cancel positions here since the last order was filled (meaning there is no current open SL order.
I don't understand what I'm doing wrong here.
Also, is there a simpler way to check that? That'd be great!
Thanks in advance.
Date Time Of Last Edit: 2020-04-13 08:35:15
[2020-04-13 10:26:23]
ForgivingComputers.com - Posts: 994
When the order is placed, save the stop order ID number in a persistent variable. Then any time you want to know the status of the stop order use sc.GetOrderByOrderID to check the status and quantity of the stop order.
[2020-04-13 11:22:16]
MattK - Posts: 42
Thank you for your answer.
The thing is that I use multiple algo at the same time and that I want to use a different algo to "clean up" orders without a SL attached.
I found a way using a while loop but I'm afraid it will slow down the performance.
[2020-04-13 11:59:54]
binaryduke - Posts: 377
Automated Trading From an Advanced Custom Study: sc.GetNearestStopOrder()
