Date/Time: Wed, 19 Mar 2025 03:40:16 +0000
Best server provider to run SC in Aurora data center
View Count: 1425
[2020-04-12 21:47:46] |
markj - Posts: 3 |
Hello, I'm looking to have SC run as close to Aurora and the futures order routing server as possible to reduce latency. The only provider I've found so far is http://www.theomne.net/virtual-private-servers/ , are there any other/recommended options for virtual private servers colocated with the order routing server and exchange? Thank you, Mark |
[2020-04-13 01:43:59] |
We will see if we can find someone for you.
[2020-04-13 10:39:00] |
ForgivingComputers.com - Posts: 1028 |
https://www.speedytradingservers.com/ has ping times to the Chicago exchanges below 1 ms. They offer a free trial.
[2020-04-13 17:10:25] |
SC Support - Posts: 1943 |
Hi MarkJ, we will email you directly with our recommendation on that. Thank you
[2020-04-14 18:46:30] |
User920967 - Posts: 63 |
I would also appreciate to be emailed the recommendation please. Thanks in advance. |
[2020-04-14 19:25:45] |
ertrader - Posts: 682 |
I would also appreciate an email please.
[2020-04-14 20:32:46] |
golding - Posts: 18 |
Please email me too.
[2020-04-15 04:32:55] |
User90125 - Posts: 715 |
Ditto. A courtesy e-mail would be appreciated please. Thanks :)
[2020-04-15 08:41:09] |
Marmany - Posts: 308 |
I would also like to receive the email with your recommendation. Thank you |
[2020-04-15 11:33:20] |
User61576 - Posts: 445 |
I will be happy to get that email as well Thanks |
[2022-10-10 17:51:46] |
User987654 - Posts: 70 |
I know this thread is old but can you please email me your preferred provider(s)? Thanks
[2022-10-10 18:02:57] |
NirvanaTS https://www.nirvanats.com/ Ambaj Sharma We would recommend them. Date Time Of Last Edit: 2022-10-10 18:29:09
