Date/Time: Thu, 06 Feb 2025 03:06:51 +0000
Time and Sales Data Sequence Jumps
View Count: 1044
[2020-04-12 05:30:18]
yellowandy - Posts: 20
Hello, I have a study that is analyzing T&S data and noticed a big jump in sequence numbers while it was iterating over the array. The backtest was run with mode "Calculate at Every Tick/Trade" and the code for accessing the T&S was taken from the examples provided (and very straight forward). When I look at the T&S window itself it appears to be displaying everything correctly but hard to verify since I can't see the sequence number there and compare. Can this happen or am I perhaps missing data? Running version 2021 and doesn't seem to happen frequently but once in a while (at the same place though which is good).
  c_SCTimeAndSalesArray TimeSales;
  sc.GetTimeAndSales(TimeSales);
  int TimeSalesSize = TimeSales.Size();
  if (TimeSalesSize == 0)
    return; // No Time and Sales data available for the symbol
  // Loop through the Time and Sales
  int OutputArrayIndex = sc.ArraySize;
DebugMessage.Format("Total Time and Sales To Process %i", TimeSalesSize);
sc.AddMessageToLog(DebugMessage, 0);
s_TimeAndSales PreviousTimeAndSalesRecord;
s_TimeAndSales LatestTimeAndSalesRecord;
  for (int TSIndex = TimeSalesSize - 1; TSIndex >= 0; --TSIndex)
//Doing some comparison here...
[2020-04-12 06:08:02]
If you notice this is during a continuous back test and there has been no restarting of the back test, then it would indicate that there are more records being added, which exceed this setting:
Data/Trade Service Settings: Number of Stored Time and Sales Records (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings)
in between study function calls.
