Date/Time: Thu, 06 Feb 2025 02:51:39 +0000
MDI Chartbook across multiple windows
View Count: 876
[2020-04-10 17:17:08] |
Fabio - Posts: 118 |
Hi there, I have multiple monitors with multiple markets at the same time (i.e. 4 markets per monitor). I'd like to have an MDI bar at the bottom of each window in order to have several timeframes already loaded up for each market. I can't find the way to have an MDI apart from the "main" instance of sierra. Can you please help me out? Thanks, Fabio |
[2020-04-10 21:22:08] |
You need to use multiple instances of Sierra Chart for this: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-10 21:22:17
[2020-04-12 14:14:38] |
With multiple instances as suggested, it means that I have to have a new instance fo every chart I want an MDI, is that right?
[2020-04-13 06:52:40] |
You do not need a separate instance for every chart. Instead you do need a separate instance, for every case where you want to group multiple charts within the main Sierra Chart window.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-13 06:52:56
