Date/Time: Thu, 06 Feb 2025 02:13:20 +0000
Additional AMP Fees
View Count: 1650
[2020-04-10 14:51:08] |
SKZ90 - Posts: 74 |
Looks like AMP Futures is adding: (See picture) Exchange fee (Mandatory) , NFA fee (Mandatory), Clearing TTnet fee (?) , Commission fee (?), while using SC Order Routing service. Is this normal? Are these fees also added with other brokers like Dorman Trading, Advantage Futures, or Phillips Capital? Is there a broker that doesn't add these fees while using SC Order Routing service? ( I know some fees are unavoidable ) Total Commission + Fees = $5.80 (20 trades on /MES) Date Time Of Last Edit: 2020-04-10 15:32:59
[2020-04-10 22:36:22] |
SKZ90 - Posts: 74 |
Bump?
[2020-04-11 01:03:57] |
We cannot answer questions about these fees but we strongly recommend that you contact other brokers like Dorman Trading, Advantage Futures and find out what the fees will be and see if you can save. 5.80 does seem high to us especially for the micro contracts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-11 02:15:12] |
Acro - Posts: 441 |
That is for 10 round turns - ie the total not the individual round turn so yes it's normal
