Date/Time: Thu, 06 Feb 2025 02:45:08 +0000
how to change point and figure bar to be based on close
View Count: 561
[2020-04-10 14:21:08] |
User150852 - Posts: 38 |
When using the study i can change the high and low values to be based on 'close'. how can i do this when using the p&f chart type? seems it works with high-low instead. i don't see anything similar to what i have in the study 'Calculate only using close price' Date Time Of Last Edit: 2020-04-10 14:28:07
[2020-04-12 06:04:59] |
This is not possible when using the built-in Point and Figure bars. Those are designed to be very accurate and stable. There is no room to use an option which will create inaccuracies or instability.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-12 06:05:25
[2020-04-12 09:07:21] |
I understand the 1st point - not possible. Can you elaborate on the 2nd a bit more? what is the issue with inaccuracy? There are two ways I can see when searching for this charts (e.g. stockchars.com), close and high-low, and 'close' takes lots of the 'noise' out compared to high-low as it has less volatility |
