Date/Time: Sat, 18 May 2024 07:25:00 +0000
Double Check Default Tick Size for ZN
View Count: 607
[2020-04-10 12:33:44] |
User486465 - Posts: 12 |
The default tick size for ZN from the SC Data service is 1/34. (See attached) The tick specified in the contract is 1/32. (https://www.cmegroup.com/trading/interest-rates/us-treasury/10-year-us-treasury-note_contract_specifications.html) |
Attachment Deleted. photo_2020-04-10_15-30-35.jpg / V - Attached On 2020-04-10 12:32:15 UTC - Size: 177.36 KB - 219 views |
[2020-04-10 13:01:15] |
You are running an out-of-date version of Sierra Chart. There is a technical notice when you start Sierra Chart about what you are describing. Update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
