Date/Time: Fri, 09 Oct 2026 00:55:38 +0000
data feed for s+p e micros and spy etf (ticks)
View Count: 1876
| [2020-04-10 10:39:17] |
| User283743 - Posts: 38 |
I am using the standard sierra chart historical data feed (plus whatever data my broker IB provides). Currently trying to recreate a TOS chart that relies on tick data for SPY etf and not having satisfying results. What data feed would I need to subscribe to improve data accuracy for the SPY etf? Similarly, what data feed do you recommend for S+P e micros? Thank you. |
| [2020-04-10 11:28:36] |
You will need to use this data feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-04-10 11:28:37] |
| [2020-04-10 15:58:19] |
Thanks for your reply. Could you be more specific in terms of what additional exchange data I need to subscribe to for the SPY etf and the S+P e mini futures? |
| [2020-04-11 01:05:08] |
You will need to activate the Real-time Data Connection for 25 USD per month And then you need to activate the US Equities exchange at 10.50 per month. Follow these set up instructions on this page: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-11 01:05:22
