Date/Time: Sat, 18 May 2024 05:24:20 +0000
Grid Lines Color Change for Trade > Trade Orders Window
View Count: 523
[2020-04-10 06:16:09] |
@TRADE_YOUR_PLAN - Posts: 126 |
Is there a way to change the color of the grid lines in: Trade > Trade Orders Window ?
Trade Orders Window.png / V - Attached On 2020-04-10 06:14:51 UTC - Size: 10.46 KB - 211 views |
[2020-04-10 11:07:25] |
This will be supported in the next release through the Text Window settings documented here: Graphics Settings: Setting the Background Color, Text Color, and Font for Text Only Windows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-10 17:05:52] |
Ah yes, I had changed it there without success previously. This is the last eyesore for my dark theme. Looking forward to the next release! :)
