Date/Time: Thu, 06 Feb 2025 02:42:13 +0000
Duplicate tools
View Count: 994
[2020-04-10 02:27:01] |
User575399 - Posts: 326 |
How can I duplicate a tool on my tool bar ? Example: having a red and green horizontal button on my tool bar.
[2020-04-10 06:25:36] |
Refer to: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-10 22:44:46] |
I read that but didn’t see what I’m looking for . I want 2 separate color horizontal line buttons.
[2020-04-12 01:48:05] |
Yes you can create as many buttons as you require. The title of the section we linked to is "Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step" It is supported to configure a Control Bar button which consists of selecting a particular Drawing Tool and Drawing Tool Configuration in one step. Follow these steps to accomplish this:
