Date/Time: Sat, 18 May 2024 05:59:25 +0000
Zigzag study refresh issue
View Count: 546
[2020-04-09 21:02:41] |
User150852 - Posts: 38 |
I am having a zigzag study on a 15min chart on the ES. i am mainly interested in the accumulated volume on the chart both high and low are set to last, and calc method is 2, 'reversal amount' and 'numbers of bars for reversal are set to 1 lets say i have a down trend and new bar starts. if new bar's last is higher than prev last, it does start to show positive volume on the new bar as it is accumulated. however, if new bar's last is lower than the prev last, the down volume 'remains' on the prev bar, and does not show on the new bar until i recalculate. then it continues to accumulate correctly on the current bar it does work and using 'calculate new values on bar close' but i do want to see the accumulation as it happens and not at the end of the period. |
[2020-04-10 06:13:59] |
We cannot help with this other than refer you to this documentation: Zig Zag: Zig Zag Reverses at Wrong Bar https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=133&Name=Zig_Zag#Inputs_InputDataForHigh Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
