Date/Time: Thu, 06 Feb 2025 03:37:57 +0000
Pulling Stacking Totals
View Count: 856
[2020-04-09 19:46:21]
User99934 - Posts: 227
Why are the totals not adding up in http://www.sierrachart.com/image.php?Image=158646146536.png
the pulling/stacking column?
[2020-04-09 20:33:14]
This is going to depend upon the particular data feed being used. There is an efficient method of calculation used and that method clearly is not compatible with the data feed you are using.
[2020-04-09 20:49:17]
I am using CQG data feed. Like you said the method of calculation is not compatible. Is there any way to correct this? Why does this happen? I'm sure Sierra data feed would not have that problem. Are there any others that might work?
[2020-04-10 07:49:15]
Well we could, but then we are developing custom methods for each service. It is not something we are willing to invest any time with right now.
Date Time Of Last Edit: 2020-04-10 07:49:36
[2020-04-15 09:21:43]
"There is an efficient method of calculation used and that method clearly is not compatible with the data feed you are using."
This is also occurring during very slow night sessions as well. When I shutdown Sierra Chart and restart, the issue is resolved and then gets worse as time goes by.
