Date/Time: Mon, 16 Sep 2024 19:20:31 +0000
DOM Bid/Ask Size Alert
View Count: 926
[2020-04-09 18:06:46] |
User624750 - Posts: 27 |
Hello! How can I set up alert (sound, popup window, color this size) for some MarketDepth bid/ask size greater then X? For Example: I am looking for bid/ask size greater then X for any price in DOM. If bid/ask size greater then X appear in book then I will receive some alert (sound, popup window, color this size). It is very important to receive a sound alert!!! Thanks in advance. |
[2020-04-22 20:42:44] |
Hello! Help me please... |
[2023-11-18 21:40:03] |
User538374 - Posts: 1 |
Interested in this too! Bumping thread.
[2023-11-20 19:50:48] |
John - SC Support - Posts: 34453 |
You can do this by adding the "Depth of Market Data" study along with the "Spreadsheet Study". You need the Spreadsheet Study in order to be able to view/manage the data as it flows. In the Spreadsheet Study you would put in the following for Column K to find all Bid Depth levels that are greater than 200 (for example): =IF(ID1.SG1@3 > 200, 1, 0) Then in Column L you would use the following to denote at row 3 if there are any values anywhere in the range: =IF(ISNUMBER(VLOOKUP(1, $S$3:$S$2000, 1)), 1, 0) You can then set an alert for when Column L is a value of 1. Refer to the following: Depth of Market Data Spreadsheet Functions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
