Date/Time: Sat, 18 May 2024 08:16:37 +0000
How do I fix Exit/Entry connection line
View Count: 806
[2020-04-09 16:33:47] |
User651753 - Posts: 77 |
How do I fix " exit/entry connection line " for pass trade history why is my display looking like this, On SIM account it looks like it working fine, but it doesn't work correctly with live account, my account often has NO contract position (close everything) so I would think it would show OPEN > CLOSE https://i.imgur.com/sq2OxET.png https://i.imgur.com/aH1eadw.png |
[2020-04-09 18:14:23] |
This is explained in detail here: Chart Trading and the Chart DOM: Accurate Entry/Exit State, Fill Matching and Position Quantities (Accurate Entry/Exit State, Fill Matching and Position Quantities) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-10 05:13:50] |
thanks it look like this fix it Use Last In First Out Fill Matching (Chart >> Chart Settings >> Advanced Settings 3 menu) Chart Settings: Use Last In First Out Fill Matching (Chart >> Chart Settings >> Trading menu) |
