Date/Time: Sat, 18 May 2024 05:59:29 +0000
Sierra Chart order routing and execution
View Count: 663
[2020-04-09 14:51:59] |
User220914 - Posts: 239 |
HI I have a question I was wondering about the TT/sierra order routing. Have you completed the ability to have LIT and MIT orders servers side? if you have done this could you add them to the drop down menu so we can use them under chart dom setting above below equal last? What order types are SERVER SIDE with the SIERRA/TT outside of normal limits that go to the CME server? Thanks in advance. |
[2020-04-09 19:41:03] |
Have you completed the ability to have LIT and MIT orders servers side? No this is really very involved and also has a potentially very very high cost from the CME for the required market data. We would not expect this for some time. The order types which are server-side are just what the CME accepts which are just the most basic ones: https://www.cmegroup.com/confluence/display/EPICSANDBOX/iLink+Order+Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-09 19:42:25
