Date/Time: Thu, 06 Feb 2025 01:00:20 +0000
Rithmic data not connecting in 2080
View Count: 539
[2020-04-09 10:37:42]
samual sprat - Posts: 343
Reverted back to 2079 and this works
Reading Internal Order ID file. | 2020-04-09 11:28:58.146
Reading Trade Orders file. | 2020-04-09 11:28:58.490
Reading Trade Positions file. | 2020-04-09 11:28:58.499
Reading Account Balance file. | 2020-04-09 11:28:58.503
UDPListener (1420). Port 22903 | Listening on UDP port 22903. | 2020-04-09 11:28:58.541
Software version: 2080 64-bit | 2020-04-09 11:28:58.541
Primary Thread ID: 3256 | 2020-04-09 11:28:58.541
Usage end date: 2020-07-24 | 2020-04-09 11:28:58.541
Enabled for: Advanced Features 2. | 2020-04-09 11:28:58.541
Enabled for: Sierra Chart Historical Data Service. | 2020-04-09 11:28:58.541
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-04-09 11:28:58.541
Allow Support for Sierra Chart Data Feeds is disabled. | 2020-04-09 11:28:58.541
Current selected Data/Trading service: Rithmic Trading | 2020-04-09 11:28:58.541
Custom symbol settings values: disabled | 2020-04-09 11:28:58.541
Chart Update Interval: 50 | 2020-04-09 11:28:58.541
Intraday Data Storage Time Unit: 0 | 2020-04-09 11:28:58.541
Time Zone: +01:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2020-04-09 11:28:58.541
2020-04-09 11:28:58 Local computer time | 2020-04-09 11:28:58.541
2020-04-09 10:28:58 Local computer time in UTC | 2020-04-09 11:28:58.541
2020-04-09 11:28:58 Local computer time in SC Time Zone | 2020-04-09 11:28:58.541
2020-04-09 10:28:56 Server time in UTC | 2020-04-09 11:28:58.541
Local computer UTC time and Server UTC time difference: 1 seconds. | 2020-04-09 11:28:58.541
Program path: D:\SC_ONEUP\ | 2020-04-09 11:28:58.541
Data Files path: D:\SC_ONEUP\Data\ | 2020-04-09 11:28:58.541
OS Version Number: 10.0 | 2020-04-09 11:28:58.542
Locale Setting: C | 2020-04-09 11:28:58.542
DLLs: BreachBot.dll, BreachBot_64.dll, BreachPoints.dll, BreachPoints_64.dll, chartdir60.dll, chartdir60_64.dll, kiwi16_64.dll, sceetobots.dll, sceetobots_64.dll, sst_ateam.dll, sst_ateam_64.dll, sst_bidask_depth.dll, sst_bidask_depth_64.dll, sst_FreeBundle.dll, sst_FreeBundle_64.dll, SST_ImportLevelsfromCSV.dll, SST_ImportLevelsfromCSV_64.dll, sst_local_pressure.dll, sst_local_pressure_64.dll, sst_Sunil_ZigZag.dll, sst_Sunil_ZigZag_64.dll, sst_volume_profile.dll, sst_volume_profile_64.dll, Trade29CustomStudies.dll | 2020-04-09 11:28:58.547
Created the DTC Protocol server. | 2020-04-09 11:28:58.551
DTC Protocol Server listening on port 11101. | 2020-04-09 11:28:58.553
Created the DTC Protocol historical data server. | 2020-04-09 11:28:58.553
HD Server Manager | Listening on port 11100 | 2020-04-09 11:28:58.555
Checking for new symbol settings. Requested symbol settings MD5 for service code rithmic.trading. Request ID: 1. | 2020-04-09 11:28:58.555
Received 5 login tokens. | 2020-04-09 11:28:58.709
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-04-09 11:28:58.749
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-04-09 11:28:58.821
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-04-09 11:28:58.821
Symbol settings MD5 received. Request ID: 1. | 2020-04-09 11:28:58.903
Symbol settings are up-to-date for rithmic.trading. | 2020-04-09 11:28:58.903
Rithmic Trading | Port for executable: 50021 | 2020-04-09 11:29:05.081
Listening socket (1476). Port 50021 | Closed. | 2020-04-09 11:29:05.081
Rithmic Trading | Starting server: D:\SC_ONEUP\Rim\DTCBridge.exe | 2020-04-09 11:29:05.083
Created process D:\SC_ONEUP\Rim\DTCBridge.exe. Parameters: /Port:50021. Current folder: D:\SC_ONEUP\Rim | 2020-04-09 11:29:05.119
Rithmic Trading | Bridge process is running. | 2020-04-09 11:29:07.265
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50021 | 2020-04-09 11:29:07.265
DTC Client socket (1) | Creating socket. | 2020-04-09 11:29:07.265
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-09 11:29:07.266
Rithmic Trading | Connected to server. | 2020-04-09 11:29:07.267
Rithmic Trading | Starting socket receive thread. | 2020-04-09 11:29:07.267
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-04-09 11:29:07.267
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-04-09 11:29:07.271
Rithmic Trading | Sending logon request message. | 2020-04-09 11:29:07.271
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-04-09 11:29:07.272
Service connection timed out. Will disconnect and retry. | 2020-04-09 11:31:05.077
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-04-09 11:31:05.077
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-09 11:31:05.077
DTC Client socket (1) | CloseSocket call. | 2020-04-09 11:31:05.092
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-04-09 11:31:05.093
Rithmic Trading | Disconnected. | 2020-04-09 11:31:05.093
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-09 11:31:05.094
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-04-09 11:31:05.097
DTC Client socket (1) | Closed. | 2020-04-09 11:31:05.097
Rithmic Trading | Port for executable: 50591 | 2020-04-09 11:31:07.113
Listening socket (1476). Port 50591 | Closed. | 2020-04-09 11:31:07.113
Rithmic Trading | Starting server: D:\SC_ONEUP\Rim\DTCBridge.exe | 2020-04-09 11:31:07.122
Created process D:\SC_ONEUP\Rim\DTCBridge.exe. Parameters: /Port:50591. Current folder: D:\SC_ONEUP\Rim | 2020-04-09 11:31:07.126
Rithmic Trading | Bridge process is not running! | 2020-04-09 11:31:09.122
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50591 | 2020-04-09 11:31:09.122
DTC Client socket (1) | Creating socket. | 2020-04-09 11:31:09.122
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-09 11:31:09.122
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-04-09 11:31:11.125
DTC Client socket (1) | CloseSocket call. | 2020-04-09 11:31:11.125
DTC Client socket (1) | Closed. | 2020-04-09 11:31:11.125
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-04-09 11:31:11.125
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-09 11:31:11.125
DTC Client socket (0) | CloseSocket call. | 2020-04-09 11:31:11.141
Rithmic Trading | Disconnected. | 2020-04-09 11:31:11.141
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-09 11:31:11.141
Rithmic Trading | Port for executable: 50603 | 2020-04-09 11:31:13.141
Listening socket (676). Port 50603 | Closed. | 2020-04-09 11:31:13.141
Rithmic Trading | Starting server: D:\SC_ONEUP\Rim\DTCBridge.exe | 2020-04-09 11:31:13.143
Created process D:\SC_ONEUP\Rim\DTCBridge.exe. Parameters: /Port:50603. Current folder: D:\SC_ONEUP\Rim | 2020-04-09 11:31:13.147
Rithmic Trading | Bridge process is not running! | 2020-04-09 11:31:15.141
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50603 | 2020-04-09 11:31:15.141
DTC Client socket (1) | Creating socket. | 2020-04-09 11:31:15.141
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-09 11:31:15.142
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-04-09 11:31:17.144
DTC Client socket (1) | CloseSocket call. | 2020-04-09 11:31:17.144
DTC Client socket (1) | Closed. | 2020-04-09 11:31:17.144
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-04-09 11:31:17.144
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-09 11:31:17.144
DTC Client socket (0) | CloseSocket call. | 2020-04-09 11:31:17.156
Rithmic Trading | Disconnected. | 2020-04-09 11:31:17.156
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-09 11:31:17.157
Rithmic Trading | Port for executable: 50612 | 2020-04-09 11:31:19.167
Listening socket (1500). Port 50612 | Closed. | 2020-04-09 11:31:19.167
Rithmic Trading | Starting server: D:\SC_ONEUP\Rim\DTCBridge.exe | 2020-04-09 11:31:19.175
Created process D:\SC_ONEUP\Rim\DTCBridge.exe. Parameters: /Port:50612. Current folder: D:\SC_ONEUP\Rim | 2020-04-09 11:31:19.179
Rithmic Trading | Bridge process is not running! | 2020-04-09 11:31:21.169
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50612 | 2020-04-09 11:31:21.169
DTC Client socket (1) | Creating socket. | 2020-04-09 11:31:21.169
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-09 11:31:21.169
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-04-09 11:31:23.173
DTC Client socket (1) | CloseSocket call. | 2020-04-09 11:31:23.174
DTC Client socket (1) | Closed. | 2020-04-09 11:31:23.174
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-04-09 11:31:23.174
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-09 11:31:23.174
DTC Client socket (0) | CloseSocket call. | 2020-04-09 11:31:23.185
Rithmic Trading | Disconnected. | 2020-04-09 11:31:23.185
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-09 11:31:23.185
Rithmic Trading | Port for executable: 50624 | 2020-04-09 11:31:25.192
Listening socket (1468). Port 50624 | Closed. | 2020-04-09 11:31:25.192
Rithmic Trading | Starting server: D:\SC_ONEUP\Rim\DTCBridge.exe | 2020-04-09 11:31:25.194
Created process D:\SC_ONEUP\Rim\DTCBridge.exe. Parameters: /Port:50624. Current folder: D:\SC_ONEUP\Rim | 2020-04-09 11:31:25.199
Rithmic Trading | Bridge process is running. | 2020-04-09 11:31:27.184
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50624 | 2020-04-09 11:31:27.184
DTC Client socket (1) | Creating socket. | 2020-04-09 11:31:27.184
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-09 11:31:27.184
Rithmic Trading | Connected to server. | 2020-04-09 11:31:27.185
Rithmic Trading | Starting socket receive thread. | 2020-04-09 11:31:27.185
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-04-09 11:31:27.185
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-04-09 11:31:27.187
Rithmic Trading | Sending logon request message. | 2020-04-09 11:31:27.187
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-04-09 11:31:27.189
Service connection timed out. Will disconnect and retry. | 2020-04-09 11:33:25.185
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-04-09 11:33:25.185
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-09 11:33:25.185
DTC Client socket (1) | CloseSocket call. | 2020-04-09 11:33:25.200
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-04-09 11:33:25.200
Rithmic Trading | Disconnected. | 2020-04-09 11:33:25.200
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-09 11:33:25.201
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-04-09 11:33:25.204
DTC Client socket (1) | Closed. | 2020-04-09 11:33:25.204
Rithmic Trading | Port for executable: 50669 | 2020-04-09 11:33:27.206
Listening socket (1512). Port 50669 | Closed. | 2020-04-09 11:33:27.206
Rithmic Trading | Starting server: D:\SC_ONEUP\Rim\DTCBridge.exe | 2020-04-09 11:33:27.207
Created process D:\SC_ONEUP\Rim\DTCBridge.exe. Parameters: /Port:50669. Current folder: D:\SC_ONEUP\Rim | 2020-04-09 11:33:27.212
Rithmic Trading | Bridge process is not running! | 2020-04-09 11:33:29.204
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50669 | 2020-04-09 11:33:29.204
DTC Client socket (1) | Creating socket. | 2020-04-09 11:33:29.204
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-09 11:33:29.204
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-04-09 11:33:31.213
DTC Client socket (1) | CloseSocket call. | 2020-04-09 11:33:31.213
DTC Client socket (1) | Closed. | 2020-04-09 11:33:31.213
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-04-09 11:33:31.213
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-09 11:33:31.213
DTC Client socket (0) | CloseSocket call. | 2020-04-09 11:33:31.217
Rithmic Trading | Disconnected. | 2020-04-09 11:33:31.217
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-09 11:33:31.217
Rithmic Trading | Port for executable: 50671 | 2020-04-09 11:33:33.222
Listening socket (1072). Port 50671 | Closed. | 2020-04-09 11:33:33.222
Rithmic Trading | Starting server: D:\SC_ONEUP\Rim\DTCBridge.exe | 2020-04-09 11:33:33.224
Created process D:\SC_ONEUP\Rim\DTCBridge.exe. Parameters: /Port:50671. Current folder: D:\SC_ONEUP\Rim | 2020-04-09 11:33:33.227
Rithmic Trading | Bridge process is not running! | 2020-04-09 11:33:35.217
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50671 | 2020-04-09 11:33:35.217
DTC Client socket (1) | Creating socket. | 2020-04-09 11:33:35.217
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-09 11:33:35.217
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-04-09 11:33:37.219
DTC Client socket (1) | CloseSocket call. | 2020-04-09 11:33:37.219
DTC Client socket (1) | Closed. | 2020-04-09 11:33:37.219
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-04-09 11:33:37.219
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-09 11:33:37.219
DTC Client socket (0) | CloseSocket call. | 2020-04-09 11:33:37.232
Rithmic Trading | Disconnected. | 2020-04-09 11:33:37.232
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-09 11:33:37.232
Rithmic Trading | Port for executable: 50674 | 2020-04-09 11:33:39.235
Listening socket (1512). Port 50674 | Closed. | 2020-04-09 11:33:39.235
Rithmic Trading | Starting server: D:\SC_ONEUP\Rim\DTCBridge.exe | 2020-04-09 11:33:39.237
Created process D:\SC_ONEUP\Rim\DTCBridge.exe. Parameters: /Port:50674. Current folder: D:\SC_ONEUP\Rim | 2020-04-09 11:33:39.241
Rithmic Trading | Bridge process is not running! | 2020-04-09 11:33:41.231
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50674 | 2020-04-09 11:33:41.231
DTC Client socket (1) | Creating socket. | 2020-04-09 11:33:41.231
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-09 11:33:41.231
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-04-09 11:33:43.233
DTC Client socket (1) | CloseSocket call. | 2020-04-09 11:33:43.233
DTC Client socket (1) | Closed. | 2020-04-09 11:33:43.233
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-04-09 11:33:43.233
Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-09 11:33:43.233
DTC Client socket (0) | CloseSocket call. | 2020-04-09 11:33:43.247
Rithmic Trading | Disconnected. | 2020-04-09 11:33:43.247
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-09 11:33:43.247
Rithmic Trading | Port for executable: 50678 | 2020-04-09 11:33:45.254
Listening socket (1500). Port 50678 | Closed. | 2020-04-09 11:33:45.254
Rithmic Trading | Starting server: D:\SC_ONEUP\Rim\DTCBridge.exe | 2020-04-09 11:33:45.256
Created process D:\SC_ONEUP\Rim\DTCBridge.exe. Parameters: /Port:50678. Current folder: D:\SC_ONEUP\Rim | 2020-04-09 11:33:45.259
Rithmic Trading | Bridge process is running. | 2020-04-09 11:33:47.249
Rithmic Trading | Connecting to the server 127.0.0.1. Port 50678 | 2020-04-09 11:33:47.249
DTC Client socket (1) | Creating socket. | 2020-04-09 11:33:47.249
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-09 11:33:47.249
Rithmic Trading | Connected to server. | 2020-04-09 11:33:47.250
Rithmic Trading | Starting socket receive thread. | 2020-04-09 11:33:47.250
Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-04-09 11:33:47.250
Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-04-09 11:33:47.252
Rithmic Trading | Sending logon request message. | 2020-04-09 11:33:47.252
Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-04-09 11:33:47.254
[2020-04-09 11:16:36]
It is not completely clear to us why this is occurring but we suspect we know what the reason is and we are releasing a new revision of 2080 in about 15 minutes.
[2020-04-09 12:17:29]
this fixed the issue for me. Thanks
