Date/Time: Tue, 04 Nov 2025 15:43:08 +0000
How do you enable DCA dollar cost average? TAKE PROFIT
View Count: 1089
| [2020-04-09 05:07:31] |
| User651753 - Posts: 77 |
How do you enable DCA for target and stop-loss? I am using a trade window with attached order for the spreadsheet when It place 3 trade $100, $95, $90 and I place a target of $10 it will then place 3 order $110 , $105, $100 Can you get it to DCA and just place a single take profit of $105 because my Avg price would be $95 |
| [2020-04-09 18:27:59] |
You just need to add the Attached Orders that you require and set the settings on them appropriately. Refer to the instructions here: Attached Orders: Step-By-Step Instructions You only need to add one Attached Order. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-04-10 05:38:23] |
here an example https://i.imgur.com/YfSgyji.gifv you can see that it adding more and more limit close order ( blue line) how do arrange it to place only 1 order also using attached order, If it has its quantity for 1 ... how do I get it to set quantity for the current open position eg 33 from the example |
| [2020-04-10 05:47:30] |
Global Settings >> General Trade Settings >> Adjust Attached Orders to Maintain Same Offset on Parent Fill .............= enabled.
| [2020-04-10 06:12:12] |
I have tried Trade Management By Study. but it moves all target to a single last order, it doesn't trigger target $10 from AVG price of the position
| [2020-05-19 16:18:10] |
bump please ,
