Date/Time: Thu, 06 Feb 2025 05:06:12 +0000
how to change a historical chart to 6months
View Count: 590
[2020-04-09 04:09:03] |
User970210 - Posts: 99 |
Hi, how to change a historical chart to 6months? thx
[2020-04-09 11:33:34] |
Do you mean 6 months per chart bar?
[2020-04-16 11:30:15] |
yes
[2020-04-16 18:50:01] |
It is not possible to set a Historical chart for 6 months and have it begin and end on the months. The closest way to do this is to set the Historical chart to be 128 days (the exact number will depend on the exchange and the days they are open during the year). Refer to the information here: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysHistoricalCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
