Date/Time: Sat, 18 May 2024 07:13:49 +0000
Question about Update and High Accuracy Charts
View Count: 592
[2020-04-09 01:04:18] |
rwilliams1 - Posts: 339 |
Just checking to see if there is any info on whether the historical high accuracy spread charts are available yet as mentioned in the link below? How to Create High Accuracy Spread or Ratio Charts |
[2020-04-09 11:56:58] |
Yes historical data support for custom calculated symbols is now available. Refer to: Custom Calculated Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-09 19:35:04] |
So just to be clear does this mean if I create a custom symbol spread chart for example: (symbol A - Symbol B), the software will accurately calculate the historical highs and lows of the custom instrument?
[2020-04-09 19:38:58] |
Yes.
[2020-04-09 20:52:08] |
So do the Difference and Spread indicators now have this high accuracy calculation built into it also, or is the only way to create high accuracy historical spread charts is to use this custom symbol function? Thanks again.
[2020-04-10 05:57:38] |
, or is the only way to create high accuracy historical spread charts is to use this custom symbol function? Yes.
