Date/Time: Thu, 06 Feb 2025 01:00:23 +0000
activation of denali feed
View Count: 564
[2020-04-08 22:52:50] |
User881178 - Posts: 2 |
hi, in your support documentation regarding activation of denali exchange data, the step of enabling the data doesn't show up for me under the account services tab; I've signed my agreements already and have made a payment; the next step should be to enable the data but it just says I'm not authorized to update. Help
[2020-04-09 18:43:36] |
We will check on this for you.
[2020-04-09 18:45:23] |
Sierra Chart - Max - Posts: 5787 |
The Data feed was being billed through your broker, which would cause the forms to not show. Your broker has now set the feed to be billed directly to you. So you should now see the Denali Activation Drop Down here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliExchangeDataFeed Sierra Chart Support Date Time Of Last Edit: 2020-04-09 18:47:59
