Date/Time: Wed, 05 Feb 2025 23:51:37 +0000
Setup of downloadtime of historical data
View Count: 487
[2020-04-08 18:24:25] |
User267701 - Posts: 66 |
Is there a setup option? i want this downloading be gone for good during my trading session. charts freeze during this process and this can get quite annoying.
[2020-04-08 19:26:53] |
No. If you are noticing a freezing issue it must be relating to the studies on the charts. Refer to this help topic: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.48 - Basic Steps to Resolve Performance Issue in Sierra Chart It has a very helpful video which provides many things you can do to resolve this. You should move the more involved charting to a sub instance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-08 19:27:18
