Date/Time: Thu, 06 Feb 2025 00:02:16 +0000
Missing data FDXMM20
View Count: 514
[2020-04-08 17:01:42] |
User649641489846 - Posts: 17 |
Hello, there seems to be missing data in FDXMM20 today Apr. 8th, 2020 from 14:55 CET to 15:02. The 1 min chart is not showing any candles for these minutes. The last 1 min candle is 14:54. Data then resumes at 15:03. I have tried reloading/recalculating and disconnecting/reconnecting to the data feed. Do you know what is driving this? Thanks Jan |
[2020-04-08 18:13:11] |
Yes we see that. We will patch this at the end of the day today. Our data provider Barchart must have had a problem with the EUREX data feed at that time.
