Date/Time: Thu, 06 Feb 2025 01:05:21 +0000
Messege Log
View Count: 542
[2020-04-08 16:56:12]
User544164 - Posts: 6
Hello, I do not know why I constantly appear Message Log with this message. Can you give me some advice? Or could you tell mi where I could send the Messeg Log? please. thanks
[2020-04-08 19:12:03]
These are the relevant messages:
CLK0-NYMEX 15 Min #5 | Caught an unhandled exception in c_Chart::WindowProc. Message: 513, wParam: 1, lParam: 18612873 | 2020-04-08 14:45:00.436 *
CLK0-NYMEX 15 Min #5 | Caught an unhandled exception in c_Chart::WindowProc. Message: 513, wParam: 1, lParam: 19464518 | 2020-04-08 14:47:35.778 *
CLK0-NYMEX 15 Min #5 | Caught an unhandled exception in c_Chart::WindowProc. Message: 513, wParam: 1, lParam: 60818204 | 2020-04-08 14:53:07.371 *
Invalid parameter handler invoked. | 2020-04-08 14:55:38.602
Message 513, would be when the pointer left button is clicked: WM_LBUTTONDOWN . Do you know if you are using the OpenGL option? Can you provide us that Chartbook you are using following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
Can you tell us what you are doing when these messages occur.
[2020-04-09 18:18:19]
We want you to update to the latest release following these instructions:
The problem could be related to this:
Notice: Exception/Stability Issue
